reserve valve leak
could be a bad valve. you can replace the petcock and see if that solves your problem.
btw the only different between the "normal" and "reserve" is the height at which the tube is able to pull fuel from. they are both right next to each other just one sits up here - and the other sits _ so you could actually fill your tank and leave it on reserve and gain more before you had to fill up again but this is dangerous cause you will not have a "reserve" to save your *** till you get to the next gas station
