Rescuing a 929 help required...
Old Jan 26, 2020 | 10:21 AM
Lofty Giraffe's Avatar
Default Rescuing a 929 help required...
Hi all, lucky (so I thought) to have rescued a CBR929rr from rot and ruin, it now resides in the warmth of my garage, a 2000 model. Lots of fixes required too many to list, but immediate issue...
I have replaced the battery cables since they had been cut, plus link leads. Key does not turn in ignition, however dash lights up if r/w lead to fuel cut off relay is fiddled with. Starter relay works when powered separately and engine turns.
apart from a match, where’s my next step
thanks
ian
Old Jan 26, 2020 | 03:20 PM
74demon's Avatar
What are you trying to do? Get it started first?
You will need to get by the security system. USA bikes have a diode in the ignition switch that supplies 9v via the pink wire to the ecu. European models have HISS, which is a different animal entirely.
Old Jan 27, 2020 | 07:00 AM
Demon
my understanding is that HISS will just stop ignition, it should allow key to turn in ignition
is this not the case
whilst powering the bike up remains an issue there are several red herrings
any advice appreciated
Old Jan 27, 2020 | 09:44 AM
74demon's Avatar
The HISS needs to read the coded key for the ECU to work. We don't have that system here, so that's about all I know about it.
Old Jan 30, 2020 | 04:26 PM
After lots of loom chasing, and switch cleaning - and ignition now turning, I have the beast turning over......but no more
what lights should I expect on dash?
trash2treasure
Aug 7, 2011 02:32 PM
zsomps6
F2 Tech
Jul 20, 2010 01:09 PM
El.T
Jul 18, 2010 11:25 PM
SilverF3
Jun 15, 2008 09:54 PM
FlynHigh71
May 9, 2008 05:16 PM
