Replacing Clutch Cable
Old Jun 18, 2008 | 01:32 PM
Rklamb16's Avatar
Default Replacing Clutch Cable
my clutch cable snapped on my 01 f4i. I bought the new able but im not sure if there are any special ways to replace that I should know. It seems pretty simple, but if anyone has ever changed theirs could you let me know anything i should know before doing this. Thanks
Old Jun 18, 2008 | 02:28 PM
rider0033's Avatar
Default RE: Replacing Clutch Cable
yeah it pretty straight forward how it looks. just remember when you put the new one on that big adjustments are made at the engine case side and small adjustments are made at the clutch hand lever. pull the cable off gently cause the is a spring loaded mechanism in the case. you dont want to pop that off or you have to take the cover off to reset it.
Old Jun 18, 2008 | 03:00 PM
Rklamb16's Avatar
is there a DIY anywhere or directions on how to do this?
Old Jun 18, 2008 | 08:46 PM
lonewolfcbr's Avatar
dude its so easy a 10 year old could do it....clutch cables are not hard...just take your old one off...and replace it with the new one
Old Jun 19, 2008 | 06:29 AM
Rklamb16's Avatar
how do you adjust it though..
Old Jun 19, 2008 | 11:12 AM
I don't know how your bike is set up...but on my f2 there are two adjustments...at the clutch lever...and right before the end of the cable on the engine end there is a fitting that the threaded part goes through...a bolt on each side and adjustments are made there...don't make it too tight...and don't make it too loose....you were probably used to a stretched cable before it broke....you want about an inch of free play at the clutch lever tip, make major adjustments at the engine end of the cable...minor ones at the clutch lever
Old Jun 19, 2008 | 02:04 PM
Rklamb16's Avatar
i thought u only wanted an 1/8inch of play (nickel)
Old Jun 19, 2008 | 02:54 PM
TK954RR's Avatar
Jan 2009 ROTM
about an 1/8 inch of free play is measured at the end of the cable going into teh lever. Or where the wire comes out of the tube you should be able to see about that much free play before it starts to engage. Lone is talking about how much at the end of the clutch lever.
Old Jun 19, 2008 | 03:05 PM
Thanks for clearing that up TK
Yea that 1/8th at the cable is much more at the lever tip.
Old Jun 20, 2008 | 01:01 PM
rider0033's Avatar
http://www.cbrextreme.com/index.php?...ew&iden=24
here you go bro. go here and download the service manual and there is the step by step in there
