Removing ignition
Old Mar 10, 2017 | 02:16 PM
Mike Burger's Avatar
Ya what I was thinking. But now that I can get into the lock is there something I can do to it so it will turn with any key for now. Until new one comes. Gunna search around also. Thanks courior
Old Mar 10, 2017 | 02:49 PM
F4I Wiring Diagram (inside))
Found it I think but don't know how to read it..lol. And what do I need to get those little tiny star screws that have a dot in middle off that holds cover on wire connections on bottom of ignition? I get all this way and now I have these tiny little suckers with a raised dot in middle that I can't get out cause the bit I have doesn't have that whole(hole even) in the middle and I think it's a little bit too big. All I have is a T10 bit.
Old Mar 10, 2017 | 02:54 PM
74demon's Avatar
You need a tamper bolt torx bit. Basically it's a torx bit with a hole in the center.
Old Mar 10, 2017 | 02:57 PM
74demon's Avatar
T10 btw
Old Mar 10, 2017 | 03:10 PM
Can u take look at diagram and tell me which wires to cross please? Last thing.
http://stuntride.com/vbstunt/showthr...iagram-(inside
Old Mar 10, 2017 | 06:01 PM
74demon's Avatar
won't be that easy. The pink wire needs reduced voltage as a security feature.
Old Mar 11, 2017 | 02:42 PM
Got it bottom comes right off after taking those tiny stars out and can just turn with anything. And now for my next trick: how can I remove gas cap assemb. Without key? Or locksmith? I made it this far without having to call one. Took all Allen bolts off and cap still needs to be unlocked to take off. I figured. I don't see another way tho. Other than locksmith. I know if I start trying to pick the lock I'll just mess it up so can't be taken off at all somehow. Lol.
Anyways am I going to be able to get that gas cap assembly off without locksmith to unlock cap. He couldn't possibly change that much just to pop gas cap right? Haha. That hopefully will be it until I want to change seat lock but that can wait
and I can't take barrel out of ignition out since key was in locked position can I? Not sliding up and out like on video thats on this site.
Old Mar 11, 2017 | 02:45 PM
Tempted to put broken piece of key in it and pray it opens. Lol. No way
Old Mar 11, 2017 | 03:21 PM
74demon's Avatar
I don't suppose you have another key somewhere....
Old Mar 11, 2017 | 03:25 PM
No extra key. Lost key code.
Haha. 15 to pick gas cap. 100 to make key with key code and a million if u don't have code. Lmao. Might as well be. I said make it to where any key will open it and eh said "we don't do that, now if I have him pick it will I be able to drive it back home with gas cap just closed as far as I can without it latching?
