Remove wire from fuse box?
Old Aug 6, 2011 | 11:26 PM
coldflood's Avatar
Thumbs down Remove wire from fuse box?
does any one know how to remove a wire from the bottom of a fusebox?
Attached Thumbnails Remove wire from fuse box?-fuse1.jpg   Remove wire from fuse box?-fuse2.jpg
Old Aug 7, 2011 | 07:33 AM
Each connection block is a little different, but they generally work the same. If you look closely at the connections from the fuse side of the block, look along the side of the metal connector that the fuse plugs into. There is usually a metal tab that is sticking out from the side. You have to use something like a straightened paperclip inserted down the side of the metal connector to get that tab to press back in. That will release the connector and it will come out from the wiring harness side. You need good lighting and clear vision in order to see the tab. Sometimes wiggling the wire back and forth will help you identify the tab that needs to be pushed in.
Good luck.
redzintimidator
How-To: Mechanical
174
Aug 8, 2014 01:07 PM
aight
May 1, 2011 02:05 PM
antatious
F2 Tech
Aug 23, 2010 05:31 PM
gabester76
Sep 29, 2008 12:08 PM
ox.
May 26, 2006 12:13 AM
