Regulator Rectifier Harness Corrosion.
Old Apr 19, 2011 | 05:57 PM
Michaud85's Avatar
Default Regulator Rectifier Harness Corrosion.
Unfortunately while i was painting my bike i had to leave it outside of my friends house for a few weeks. I finally have it back together and running then it just dies on me. Checked the fuses all was good then i knew it had to be the r/r.
turns out its not the r/r its one of the harness wires that got badly corroded and now separated from the harness.
I cant find any harnesses and alot of the r/r's on ebay dont come with a harness attatchment.
Any ideas? I dont know of any great way to put make sure the wires are all solidly connected into the harness again so i figured a new one is in order,
Old Apr 19, 2011 | 06:30 PM
justasquid's Avatar
Is the wire bad at the plug? or is it just mid harness somewhere?
If its mid harness, it should just be a simple matter of removing that wire and installing a new one.
If its at the plug-in, you have a few options. The cheapest would be to bypass that wire. You can cut the wire from the harness, and then from the R/R and then plug them into eachother directly with a set of terminals.
Or, you can buy a universal pin connector and rewire your harness that is on your bike, and the harness that comes from the R/R.
Either way will be much easier tha replacing the entire harness. Plus, if you buy a used harness, you may be buying one that is in the same condition as your current one.
Old Apr 19, 2011 | 07:25 PM
Michaud85's Avatar
one of the wires got corroded and actually came out of the harness we jammed it in there with a screw and the bike ran fine again for a few minutes before dieing
KRUSHER F3
Apr 14, 2019 08:56 AM
9D3900RR
Feb 16, 2011 07:50 PM
pinkcookies26
Oct 18, 2006 10:33 PM
