Rear wheel hub bearing will not come out. HELP!
Bike is disassemble with rims getting powder coated so I decided to change out the wheel bearings that didn't look that great. The rear wheel hub bearing will not come out and it seems as if the dust seal is part of the Hub. Any suggestions
Have you taken off the final drive flange and removed the cush rubbers
Yes, I'll try to post a pic, ok no pic and at work. Anyway it is strippedal down to just hub bearing and seal. I got the other bearings removed by tapping them out with a socket. This bearing took a beating and won't budge
Have you got one of these, I see your in the USA, turn wheel over and come from the other side
https://www.ebay.co.uk/itm/TEKTON-5-...8AAOSw3ZNZ4rN6 or maybe one of these, Harbor Freight may have them https://www.ebay.co.uk/itm/Inner-Bea...0AAOSwyQtVkkJk |
No I don't have one of those I was trying to avoid spending the extra money. Lol but if that sounds like what I have to do then I can rent it
The slide hammer tool is good ,but sometimes even they need a little help from the drift the other side, but great for taking out internal bearings (that is bearings you cant reach from the other side)
Thanks bud, I'll give it a shot
1 Attachment(s)
This is one I took out of a swingarm using the tool
