RE:leak down test?
Old Dec 4, 2005 | 04:39 AM
allday's Avatar
Default RE:leak down test?
Do you need to take off the cylinder head cover to perform a leak down test?
Old Dec 4, 2005 | 05:18 PM
chainstretcher's Avatar
Admin Emeritus & MVN
Default RE: RE:leak down test?
Yes -- the valve cover has to come off so that you can verify TDC by the cam alignment. Even a couple degrees off will make the readings garbage. As a side note: most bike valve covers are a bee-yatch to remove. Usually the throttle cables and a slew of other goodies must be removed to get it gone. On some models it's easier to remove a couple of engine mounting bolts and tilting the engine down to remove.
TheX
Dec 28, 2008 11:00 PM
cdrewferd
Feb 28, 2008 09:15 AM
krash
Dec 2, 2007 03:53 PM
travsstuff
Nov 25, 2007 10:52 PM
allday
Nov 30, 2005 04:26 PM
