Ratio Theory *version 2
I'm stuck at work, not allowed to leave on the off chance that the boss wants something done!
If I had the option, I'd always be out on the beast!
I'm gonna edit this post instead of making a new one so it doesn't keep going to the top of the list.
I forget my terminology... maybe by "varying constant" i mean "varying factor" this factor would be related to all the things you said... but you've found my limit of interest in excel! I don't care about it enough to go any further with it... It hurts my brain.
FYI, I did ride yesterday....at a faster pace than usual I might add.
Regarding the constant change in tire size: It wouldn't be constant. Road temperature would affect the expansion constants. Centrepital forces can be calculated, but as the tire heats the rubber becomes more compliant, and thus stretches more.
Regarding the spelling: I understand that English is from England, but this server is AMERICAN DAMMIT!!
LOLOLOLOLOL
LOLOLOLOLOL
ORIGINAL: Triangle
Alright, we are done talkin about tyres and tires and centrifugal fuel ratios to the factor of 9 to the 3rd power divided by the weight and height of chain lube in a 10 gallon jug with 3 nails in the tire and a 180lb person on my back squared than multiplied by pie subtracted by the first 3 numbers I said and adding the baby thats holding on to the rear pegs because you forgot to use your safety belt when you crashed into the man carying the 3 shotguns with his mouth while setting his nuts on fire.
No one wants a thread about that in here![Big Grin](https://cbrforum.com/forum/images/smilies/biggrin.gif)
DThompson - "The Scientific Mathmetician" BOO YA
ORIGINAL: DThompson
ORIGINAL: Jaybird180
The answer is Blue
ORIGINAL: DThompson
O.K. the answer is blue -- but if you go deeper the sub-answer is:
The tach is off -- by as much as 250-400rpms depending on engine speed. A lot of peeps will see red on the tach and think their limiter isn't working -- it's just that the tach is off. Notice on any of the manuals that describe synching carbs/throttle bodies -- most of 'em will specify that you attach an external (read: accurate) tach.
And if you don't have a speedo healer then most likely your speedo is off too.
On my avatar you'll see my max speed -- theoretical speed for that gearing was 235mph but I was bouncing the limiter and only got 228mph. So clutch slip, tire slip played a factor.
ORIGINAL: Tahoe SC
you have it all wrong meng...
ratio theory says that one person is better than the other based on color of skin or ethnicity...
very flawed theory.
very flawed theory.
ORIGINAL: chainstretcher
