Radiator Fan Not Kicking On
Yesterday I was in traffic and witnessed my temperature gauge rise and rise got to 250. Luckily i got on the interstate and cooled it down. I turned it on today and watched it rise to 225 and the fan never came on.
I ride a 2003 CBR 600RR and am wondering if anyone has ever experienced anything like this. If so I would really appreciate the help/tips. I'm wondering if I need to replace the whole radiator/fan or if it is something electrical.
Thanks,
Drew
Thanks,
Drew
Well before you check the fan directly, check the fuses. If the fuses are good, you can either check the fan directly or use a voltmeter to check the wiring. Checking the fan is prolly easiest. If the fuses are good and the fan works, then you should begin checking the wiring. Your service manual should have the troubleshooting steps for which wires to check and voltage to expect.
If everything still checks out good, it could be your thermostat. That's a little more difficult to test (requires you to boil water ).
Basic ts for anything electrical on your bike (pretty much everything) should start with the fuses. It's the simplest check availible (admittedly I assumed you already checked them)
*UPDATE*
Tonight was a very lack luster night that just left me somewhat frustrated. Below is what I did.
-Checked Fuses. All are ok.
-Tested Voltage on Fan Relay. Although my buddy and I couldn't really stay that steady it looks like the relay is sending on 12v as it should.
-Attempted to run battery directly to fan. Now this is where I need everyones help because I don't think I was doing this right. Does anyone know how I would connect the battery to the fan? My buddy and I were holding our wires to the back of the fan where it looked like the normal wires ran. We also tried to go straight through where the relay connects.
All these attempts brought me nothing. I hope someone out there can give me a hint so I can try something new tomorrow.
Thanks all!
Thanks all!
