Power Commander
Old Apr 20, 2006 | 12:23 AM
arkas's Avatar
Default Power Commander
Holy crap, I just installed a PCIII usb on my 03 CBR 954 and what a difference! I am amazed how much it improved the bike overall, this product kicks ***. I love to ride my 954 before the PCIII but now that I installed one it is just amazing how big it improved the overall response, its like riding a new bike, it smoothed the acceleration out and gave a nice bit of extra punch.
If anyone is THINKING about getting one of these but not sure if its worth it, trust me its worth it. I wish I bought one earlier, one thing for sure if I get another bike I will be getting a PC also.
Did anyone else notice a big difference when they installed a PC?
Old Apr 20, 2006 | 12:33 PM
GRUNT_Jarksbro's Avatar
Default RE: Power Commander
Just installed one on my 2004 f4i
it does make a difference. I notice it at the low end a lot. My front wheel comes up a lot easier than it used to.
I have some tweeking to do because i have a flat spot at about 5k rpm. But i like it
Old Apr 20, 2006 | 12:56 PM
954 RIDER's Avatar
Thanks for the post. I've been tossing around the idea of getting one for my 02 954, good to know.
Old Apr 21, 2006 | 12:06 PM
RiPTOR's Avatar
I've had mine installed for a few weeks now and love it. Throttle response is great, and also very smooth. I'll be installing power commanders on every bike i own now.
Old May 22, 2006 | 04:15 PM
amadres's Avatar
Do you have a full pipe or just a slip on?? I have a 05 1000rr with just a slip on and everyone tells me it does no good unless you have a full system.
Old May 22, 2006 | 05:52 PM
hotwire's Avatar
amadres i have the same question and heard the same thing but if you can and it is good for a slip on i'm there
Old May 22, 2006 | 08:35 PM
amadres's Avatar
Me too, that is the only reason I haven't installed one.
Old May 22, 2006 | 09:40 PM
HighRevver's Avatar
I am confused on a few aspects of the PC's,
1) do you hook it in and once you run it you remove it or does it have to stay connected to the bike.
(someone complained of the PC taking up too much space ontop of the battery to fit the alarm in there)
2) Does the bike have to be dyno tuned? Like do you not have to but is it a good idea?
3) If it doesn't require a dyno then how do you install/run it on the bike?
Old May 22, 2006 | 09:56 PM
CHEEZEWIZZ's Avatar
from what i have seen you install the p/c in line to the main computer module and you can connect it to your laptop and install pre set tunes you just go to the site and tell it what you have. like full pipe and air filter, gearing and so on but it stays installed on the bike , its a simple install. you may opt to go to a local dyno shop and have a special tune put on your bike and that would be the best option but it runs about 300.00. so try the pre set tunes first while wating on the cash flow. As for the other questions i have a 929 with an air filter and slip on and it made a differance with my bike. you just need to remove the emission valves in the mid pipe. Honda made the header pipe so well it does not need to be replaced it flows the same as the erion.
Old May 23, 2006 | 03:03 AM
amadres's Avatar
what kind of difference? I would still like to hear from more people if its worth investing in the PC with only a slip on versus a full exhaust.
