Plugs and Air Filter
RE: Plugs and Air Filter
Ive found out that on my bike when the plugs are fouled there done. If I pulled the choke all the way out it wouldnt start and id start getting the back fires. Now i just pull it about half way up. It works fine now. Could be a choke problem, carb problem, or your floats may be sticking. Id look there first
Go to your local Honda dealer. The techs there are awesome and can def. help you out. they will give you the right spark plugs, the right air filter (i paid about $57.00 for my air filter, but it was K&N) and they can most likely tell you what is wrong with it. but i would go with what sirlipz said and make sure your firing order is correct. the numbers should be engraved or etched on the motor itself.
Thanks Everyone for the help....next weekend i'm going to go through the whole bike and try to get it up and runing. At this point I'm sanding down all the plastic gettin it ready for a new coat. Also I'm searching ebay for a black seat cover and an air filter. Cross your fingers I would love to be riding in a couple of weeks!!!!!!!!Thanks Again ya all are great!!!!!
