Piece of crap bike
Old 06-01-2013 | 11:50 AM
stevepet's Avatar
Default Piece of crap bike
I almost died on the highway last night, both hi/low beams cut out, an then my bike starts to bog out, the bike is rideable but if I go near 5k rpms the needle will drop and go crazy and then ill get a crazy loud pop out of the exhaust, I can't start without pop start , 0 charge in the battery and it was fine all day yesterday. I'm going crazy with this bike I want to throw it off the bridge. She no longer has my love
Old 06-01-2013 | 01:04 PM
vfrman's Avatar
Party Animal, ROTM June 2014
Sounds like the reg/rect went out and the battery drained. That is where I would start...
Old 06-01-2013 | 01:09 PM
CJardine's Avatar
Track junkie & modaholic
replace the alternator with the r/r too.
Old 06-01-2013 | 09:16 PM
stevepet's Avatar
That's what I've Ben thinking all day, just got back to my bike and tossed on cables and it would rev fine seems like I was puttin to much power to the lights and they blew, idk about the engine misfiring and bogging though
Old 06-01-2013 | 10:42 PM
Bryce Swartzwelder's Avatar
Default check the battery
Not knowing just what is wrong with your bike, i suggest one thing. Have your battery tested, for load and for short. Shorted batteries cause a lot of alternator failures. Bike batteries are notorious for faulting due to nature of abuse they are subjected to.
Old 06-02-2013 | 11:32 AM
stevepet's Avatar
Well I bought a new battery a month ago and it seemed to be doing great until the other day
Old 06-03-2013 | 10:34 PM
stevepet's Avatar
do i just need a new wiring harness or do i need to check the actual wires for burnt ends?
Old 06-05-2013 | 03:29 PM
jeason15's Avatar
Dude, not hard. stop freaking. your battery went dead, which plays hell on your ignition system, causing it to not run properly. Check the R/R, the stator windings, and have the battery tested. you should be able to read these all out very easily, and if you tell us what bike and year it is, i can even tell you what to read, where it is, and what it should be.
Old 06-06-2013 | 10:53 AM
stevepet's Avatar
first off my battery was fine. my bike started fine the other day. the dead battery is a result of a electrical gremlin in my bike. i replaced the r/r and went for a test ride, the massive misfire went away. the blinkers wont blink unless i have the clutch and throttle disengaged. the speedo no longer gives me my speed. it goes up with the rpm. the bike still boggs a little if i give more that half throttle. i have a crappy analog multimeter that i barly know how to read. i dont know a lot about bikes and i know even less about electrical, but i know how to follow directions pretty well. i have a 1998 cbr 600 f3
Old 06-06-2013 | 11:01 AM
John Cu's Avatar
Take it to a bridge and Let it Gooooooo!!!! Lol...
Quick Reply: Piece of crap bike
