PCIII question
Nope, I checked the fuses and they're all good. I took the PC3 off and hooked the original plugs back up and she started right back up.
I was thinking: Is the small black wire supposed to go to the battery or just to a bolt on the frame in order to be grounded?
Destructions say negative lead to negative battery terminal:
http://www.powercommander.com/powerc...36&yr=2006
Is there no power to the bike? or no power to eh PC3? Did you hook up the connectors to the proper throttle bodies? Try hooking it up and instead of connecting to the bike battery, use a 9 volt with the adapter just to see if the PC's getting any power.
Yeah there's power. When I turned the key, the lights and the ECU came on. But the fuel injection didn't kick in. The PCIII didn't even blink and my bike would crank when I pushed the ignition switch.
