Hi All, Does this sound like the CCT? Quietens down when warm. Stays the same when clutch is pulled in / out, however i think it gets quieter once i release the clutch and the bike is in gear. Thanks
sounds like that although can't be 100% sure. The usual give away is the noise is much more apparent/pronounced when the revs drop(as you let go of the throttle)as the chain is relieved of tension
