Omg damn throttle
ok well how do you adjust your throttle to where its easier to turn? i just installed my new zombie bars today and i cant seem to firgure out how to make it easier to turn
Do you have the grips on? If your throttle grip is too far in, it may be friction against the switch housing.
yep its on and its not rubbing, infact i had to cut the end open so it could fit around the clipon and reach the cables
sounds like you have taller bars, and it might be putting your cables in a little bind - even if they had enough slack to reach their new position - the throttle cables need to have a proper curve to them to allow the cables to slide freely in the housings.
they are the stock lines and aftermarket bars, but all i wanted to no is how to adjust it, like which one do i tighten and which one do i loosen
