Oil leak by water pump
Old 05-23-2011, 01:32 PM
adrenalnjunky's Avatar
chisel/angled drift in the groove where the clutch cover meets the block, light taps from a hammer - move around to a few spots to gently tap it loose. Use a flat-head screwdriver if you have nothing else available.
there's a gasket in there, so it might be a little stuck on.
Old 05-23-2011, 02:48 PM
Freekman's Avatar
thanks you guys have been really helpfull im hoping to get my baby back on the road asap
Old 05-23-2011, 06:31 PM
Freekman's Avatar
i am having a lot of trouble getting the clutch off, so maybe this could give you guys more info on what is causing my stalling problems. It would start the first time then it would stall out and after that i would here kind of a spraying sound or hissing when i hed the ignition, but it would not start unless i turned the bike completely off and started again
Old 05-23-2011, 11:16 PM
pull the cover off your waterpump housing, and see if you can turn the impeller blades by hand.
Pull the waterpump out and inspect the shaft for damage.
Old 05-24-2011, 11:48 AM
Freekman's Avatar
i'm going to try this when i get home, but you are saying that if i can move the impeller blades on my own it would not be the oil pump, bucause the impeller looks pretty good, i already took it out. i think that once i got the new part im going to start trying suggestions from another forum i found. ill post the links if anybody wants to see i just am guessing it is against the rules here
the shaft looked fine, but i couldnt spin the blades by hand, is the oil pump shot
Old 05-25-2011, 02:41 PM
Freekman's Avatar
alright back to the original point of this post which is the leak. so would it be safe for me to use liquid gasketing in around the water pump, because i want to make sure that this area is sealed
Old 05-25-2011, 06:13 PM
I personally wouldn't use liquid gasket on anything. Just use the gaskets that you get from Honda and they'll do their job. The last thing you want is for some of that stuff getting someplace it shouldn't.
Old 05-27-2011, 11:31 PM
Freekman's Avatar
alright i got everything patched up and the bike is running, but she dies if i dont hit the throttle, it seems as if the choke isnt working either
Old 05-27-2011, 11:36 PM
Has the idle speed been set too low ?
Old 05-28-2011, 10:16 AM
Freekman's Avatar
yes
Quick Reply: Oil leak by water pump
