No power to tail light or gauge cluster
i was riding tonight when i realized all the sudden i didnt have any power to my gauge cluster, no rpm readings and nothing was lit up EXCEPT the high beam light stayed on the cluster and when i hit the turn signals they also lit up. no neutral light, tac, clock, speedo, etc had power.. Also my tail light is now out. is there a fuse that controls these specific controls somewhere? we pulled into a parking lot but couldnt find the fuse box, where is it.
-mike |
your fuse box is located under the upper left side of your fairing should be able to pull a few bolts and locate the box
i'm having same issue , was it a fuse?
I had the same problem on my 02 F4i last week. I thought my speedometer was bad but it was just the fuse. I had a wire touching metal and it kept popping my fuse for the tail light, speedometer and license plate light. Id check that fuse I think its the third one from the top if im not mistaken and also check for any loose wires. After I replaced the fuse and fixed the wire that was touching I didnt have anymore problems.
:icon_bike: :icon_bike: :icon_bike: |
