No power to brown connector to fuel pump
Bike has been sitting for years...no fuel pump prime.\
So i took the tank out to inspect the brown connector. no voltage; however just to check to see if my multimeter sucks, i checked the black connector and is getting voltage. service manual says to check main fuse (good), bank angle fuse (good), sub fuse (good) relays i used a lead tester, doesnt read (not sure why) but the relay doesnt click when put in the "on" position, when i removed the engine cut the buzzing sound near the injectors stop, but when i put it back the buzz comes on (not sure if thats a problem), disconnected and reconnected fuel pump relay and it clicks, moved around the relays to see if theres any volatge going to the brown connector (nothing). played around with bank angle sensor and the relay clicks, last thing to check is the ecm...any thoughts fellas?
