Nikasil?
thanks for the info guys. now i want your oppinions, is the over bore worth it? the shop i went to quoted me $500 for the bore/nikasil.
or should i leave it how it is and just continue with my other build plans?
My other plans for the engine is, port and polish, lightened crank, f4i intake cam, f3 intake on exhaust side, and adjustable cam gears.
What is the compression ratio oem and what it will be whit the 2mm oversize pistons and what will the displacement be whit the oversize pistons? What is the rev-limiter on f4i and what is it on the f3?
Does it have a iron sleeve? I looked at some F3 pics at ebay and they do have iron sleeve. I wouldn't nicasil iron sleeve. You can run little tighter piston to cylinder wall clearence which could be worth few hp but i think boring and honing the oem sleeve will be more cost effective. Ask for pricing on some machine shop that does borings. Is there anything wrong whit your pistons or cylinders? If they are fine it is not worth it. Cams, porting and a good exhaust will give you probably better gains.
not sure about the rev limits, but on the f3 redline is 13,5 and 14,5 for the f4i.
But since it is sleeved would i still need the nicasil? thats where the real cost is for the overbore.
youre right, they are sleeved actually, Nothing wrong with the pistons or cylinders though, doing all this for Sh**s and giggles...and to have an even sweeter f3
But stock f3 comp. is 12:1, with the f4i pistons it would take it to 12.5 or 12.6:1.
not sure of the specs on the cams, cant seem to find them anywhere, and dont have anything to accurately measure them with at the moment. But the lobes on the f4i cam are 2.5 mm wider apart than the f3's. it still fits, but it looks like ill have to grind off some burs/ridges left from the casting process.
i do plan on getting stiffer springs, and i wouldnt be grinding off the cam towers, it would be the area around where the springs sit. shes not a cali model. Not sure if i would be able to increase the rev limit or not. researched it a bit and havent found anything.
Whit dyno 2000 ignition you should be abble to increase the rev-lmit to what you need. What springs are you planning on using? You should take few photos of the cams and were you need to grind the head.
Ill look into the ignition. Not sure what springs ill use, really just getting into all this.
heres the head.
theres the little ridge from casting, and the spot where it dips down so the lobe clears, since the lobs are wider apart it may cause an issue, But im just setting it in there and spinning it, ill have to actually bolt on the cover that holds the cam in to know for sure
heres the head.
Are the lobes wider to bouth directions or is the spacing different. If the spacing if different you will probably run in lot of trouble whit the F4i cams. They wount hit the lifter/bucket properly if the spacing is wrong and it will wear the lifters and lobes. Is the spacing of the journal surfaces same on the F4i as the F3? Has it been done before?
There is lot to think whit these kind engine modifications. I ran in to lot of things to consider when i started building the 954 motor. I think i got them sorted pretty well but the engine hasn't run yet so will see how is the drivebility of the engine be. I'm personally little worried about that.
Whit your 2 mm overbore, added compression, cams etc. you can run in to lot problems whit the engine head. Is the stock valve sizes enough, does the valve angles work whit the bigger bore, how much do you need more air through the head etc.
