New Rider with a 2002 cbr 600f4i purchased yesterday
a few questions
What does the little B mean on my digital speedometer? Its on the bottom of the screen inside a little square.
What rpm do you normally shift at? (I also asked this in the new member section) My engine feels like its going pretty hard at 7000 rpm but again what do I know.
What type of oil should I use?
The B is for your trip odometer. You have two, an A and B, not sure why we have two, I dont use the one I got in the car. lol I really never paid much attention to the tach when I shift, but I only got a few rides under my belt, I just go by feel, probably arond 5 or 6k. I've been drivin stick shifts all my life. (well half of it)lol. As far as oil goes, atlot of people suggest Amsoil, I got some Lucas off eBay, but its my first oil change, but whatever you use make sure its motorcycle oil cause we have a "wet" clutch, which means it uses the oil from the motor, so you cant use car oil cause it will cause the clutch to slip. Cange the plugs too, but they ain't cheap. 40-50 bucks for the set NKG Irridium plugs, dont remember the number, look it up in the manual, which can be downloaded from one of the "stickeys" here. Search the forums, gain as much knowledge as you can, and PLEASE for petes sake DONT pay the STEALership to do anything. Whatever probs you run across are discussed here, just ask. (like you did). Ride safe bro
These answers to those and more can be found in The Ownwer's Manual or in The Service Manual.
Not specific to your bike, but...
I don't have the same bike but if you're really new to riding a couple of things that might help.
When it comes to shifting there is a wide range of what could be called the "right" shift point depending on the circumstance so getting an exact answer like 4,000 could be hard. For example, if you're going for maximum acceleration then letting the engine wind up through the RPM's where it produces the most power is desirable but for normal street riding that's not appropriate.
I'm not sure what others think about this but I've found that for street riding (not highway) you want to be hovering around the RPM's where the power starts to ramp up. The idea being that if you need to make a quick escape from a bad situation it's good be be close to where the power band is handy so a quick twist of the wrist will give you some instant speed. By paying attention to the how the bike sounds and feels when riding at your target RPM's you'll quickly learn when you're over or under revving the engine and shifting is just a matter of staying in the 'sweet spot' for what you're trying to accomplish. It's a good idea to look up and know something about the power curve of your bike - where it starts to make power and where the power curve starts to weenie out and where it red lines.
As for which oil to use - you are going to get different opinions from everyone. First off Some will say use synthetic from mile 0, others say switch after 1k, 2k, 3k,... Everyone has their favorite brand and brands they hate. Your owners manual is your friend on this one but whatever you do, DON'T SKIMP.
Trip meters - I actually use mine. I always reset "A" when I fill the tank so I know how far I've ridden since the last fill-up, and hence how far before I'm likely to need the next one. I got in that habit on my dual-sport bike because I like doing longer rides and tracking fuel use can be a big deal if you're crossing a long stretch with no gas stations. Since my GS only shows usage after you're past the 1/2 full point it can get dicy if you're not on top of it. I use "B" to keep track of my "current" ride.
Shift wherever you want dude. The red line is there for a reason so don't go over it. If your having fun take it up to 8k why not as long as you have a clear path in front of you and no possible hazards. Red line it from time to time once you built up that confidence. Red line in first gear will take you to over 50 surprising so there isn't much more to do past there on any normal road. It will help you learn how to handle your bike and make you an overall better rider. For normal casual riding in the city, I shift 4-6k keeping the rpms closer to the higher torque rpms around 4-5k.
Oil, not sure but I'm going to change it in a few weeks. We'll see
Anyone know if buying the Honda oil like my buddy used to do when he had the bike is necessary?
I've heard the Rotella-t synthetic Shell oil (am i remembering the name right?) supported by most people on here and thats what I'll be using when my next oil change is due. There's a thread on the topic somewhere around with a lot of good info on the topic, so you can do a search for it.
Here's some good oil stuff: Motorcycle Motor Oil, Oil Filters Revealed, Motorcycle Oil & Filters, and Oil Forum.
Guest
Posts: n/a
Most people that have driven a manual transmission car before they ride sportbikes suffer from the same problem. They are so used to shifting at a certain poiint or at a certain sound that they are completely off when shifting bikes. An f4i redlines at 14,000 rpm, and will run completely comfortably at 6 grand or more all day long, and shifting at around 10k or even higher won't hurt them. Now to a 4 wheeled stick driver running a motor at 6 grand just sounds wrong, sounds like its going to blow or something, while in reality these motors are designed for it. Most people shift way too early on sportbikes, even for casual riding. Cruise around 4k rpm if you want mileage and shift whenever you want, just don't worry about hurting it ever if you let it run up to 10k before shifting, you won't.
As for oil use Rotella T Synthetic.
jharbinson
02-22-2009 09:55 PM
