Need Help With HID Install
I just bought a HID kit off ebay and I can't figure out how to run the postive and negative wires off the HID bulb into the factory wire harness. The problem is that there is a rubber like washer around these wires on the HID bulb. Soyou would have to bend them back around and over the rubber washerto plug into the bike wire harness. If you do that then I would lose my seal around all the wires then take a chance of leaking water one day into the bulb. Would it be ok if I cut a small hole to pull the wires back out of the rubber washer and use a little silcone on it to seal the holes water tight. I have some thats clear. This is my first time doing anything like this so just looking for some help. Thanks.
[IMG]local://upfiles/13191/499BB953FB4042A3A111576357A1C0FE.jpg[/IMG]
Ive never done an HID install but soon will be doing so. I am curious about your qestion though. Are you trying to hook up the hid bulb to the stock wiring harness? or are you trying to hook up the ballist and or igniter up to your stock wiring harness?
Im assuming your kit has the ballist and the igniter correct? I thought the bulb plugged into the igniter.?
I know, my spelling is off.
You have to hook up theHID postive and negative wires into the factory bike wire harness. My problem is just getting them to hook in while still having a water tight seal. I just dont understand why they did the wires like that knowing you have to bend them back around to plug into the wire harness.
nope the ballasts are supposed to run to the factory wiring harness, not the bulbs. maybe u got bad directions. 12-14 volts isn't enough to run hid bulbs, the bulbs need incredibly high voltage to ignite, which is why you need the ballasts... and the ballasts need to be switched on when the headlights are supposed to be on, which is why they plug into the factory harness. if you were to plug the factory harness to the bulbs, they would only see 12-14 volts and they would not work. thats why the wiring harness has traditional insulation and the wires off the hid bulb have silicone or rubber insulation, because the extremely high voltage that those wires are meant to conduct (from the ballasts) is so much that it would arc together through traditional insulation.
ORIGINAL: waynecbr600rr
I have the ballast for both bulbs. And for my kit, the bulb wires into the factory wire harness and everything else plugs into each other.
