need help cbr has been sitting a while
i just aquired a 2001 CBR 929RR. It only has 12500 miles on it... the only problem is it has been sitting for at least 4 years... anyways i was wondering what the best steps are to get it back into good running condition. i have already siphoned the gas out put new gas in it and added octain boost and a lucus oil "tune up in a bottle". oh yea and a new battery thanks for any input
sweet!/new info
when i first got the bike i siphoned the gas out of it and put some premium in it then tried to start it and it ran for a little wile then the next time i tried to start the bike it wouldn't start because the battery was crap. new battery then it wouldn't idle right so i siphoned the gas out again and put the octane boost in it and the injector/ tune up in a bottle thinking it was bad gas but the new battery was to weak from trying to start it so many times and now i have it on a slow charge hoping that when it is done charging everything is all good but good advise... i was debating the tires since they have good tread. but if they are dangerous because of dryness and flat spots then i will look into new ones...but i was looking into tune up advise and you had some good ones... hopefully the fuel filter isn't clogged...but on the tire note got any advise on tire brand?
The idle screw is on the left side of your bike near the servo motor. Its a black **** about the size of a dime that lets you adjust the idle.
more questions
there is visible rust in the tank whats the best way to try and remove it? just a wire brush and flush it with some of the gas i removed from it? can i clean the fuel filter or should i replace it? thanks for the help I'm new to working on motorcycles but I've been working on cars for a long time. i cant wait to ride the bike so I've been trying to do minimal work to it so i can actually ride it before winter comes. i should have known from previous work on vehicles that the short way out usually doesn't work out in the long run
Did you get your spark plugs changed yet? Will the bike run at all right now?
the honda shop was closed today so im going to go tomorrow... the oil leak is coming from the crank case cover so im going to get a new gasket as well while im there... is there anything i need to look for or do while i have the crank case cover off? oh yea what about the fuel filter should i change it or just clean it?
Sounds like your Fuel Pressure Regulator is bad.
