Need 929/954 lower triple info
I need to know what the fork diameters and fork center spacing is for the 929/954 lower triple.
I put 06 GSXR750 forks and triples on my F4, however the fork center spacing is just bit too small (GSXR750 is 207mm). As a result it is pinching the rotors in the calipers. If the 929/954 lower triple has the same fork diameter (need 53mm) and wider center spacing, then I could solve my rotor issue.
Thanks,
Chris
Thanks,
Chris
