Mototek undertail install instructions???
RE: Mototek undertail install instructions???
i put a powerbronze undertail on my bike just yesterday. i used a jig saw and cut the entire floor of the stock undertray out, leaving only the side rails. this is needed as towards the top of the tail, ie, tail light, there are bolts which hold the undertray to the frame. be sure not to cut to much material away, take time and be precise with measurements, its alot harder to put plastic back on then it is to cut it off. make sure you retain the factory battery tray.
good luck, its really not that hard when you get down to it.
Have fun with that brother. I installed one of those on my bike a couple months back and the instructions didnt help for jack. Basically you have to cut off any part of the old fender that would be seen if you can imagine the new one there. I basically did a guess and check with the trimming. The fun part is when you get to the wiring. There is a whole lot of splitting going on. Im not really sure how i even got them working. But anyways, good luck.
tryhttp://www.58cycle.com/images/parts/..._gp_underta... hope this helps. still a pain in the *** but at least you'll have instructions &pics. mine exotic sportbike brand same asmototek &no instructions either.
that link seems bad but here is the link to mototeck's site www.mototeck.com just pull up you bike and and the undertail than just click the link for installation
sorry about the bad link above . this is it here.http://www.58cycle.com/images/parts/...stall_inst.htm
Sabotage
04-27-2014 07:24 AM
Drippps
05-12-2011 12:30 PM
900, 929, cbr, cbr1100xx, honda, instalaion, install, instruction, moto, motorcycle, mototeck, mototek, powerbronze, teck, undertail, undertray
