Making Gaskets
I've made many gaskets out of gasket sheets, but never out of random rubber sheets. Without knowing what the material make up is, there is no way to know if would stand up to the abuse and not degrade. The gasket there has to be able to withstand high temps, gas exposure, vibration...ect.
You could probably buy some good gasket sheets from your local auto parts store and start off with the correct stuff. Tell them what its for and they should be able to get a material that will hold up. Then, just simply cut it with a razor blade to shape. Holes are best cut with a tube of some sort. I actually have hole punches, but I have used two washers compressed, one on each side of the gasket, then a bolt that just fits through the hole on the washer tapped through makes a good clean cut as well. Drill bits work, but tend to just rip and tear the material. You can also use the washers and take the razor blade using the washers as a guide and that can leave a decent hole.
cool, I wasnt sure if you were just talking about rubber sheets. Its good you meant the gasket sheets, I just wanted to make sure.
as far as float bowls, I've never made them before. It might be a bit tricky, since most float bowls are actually more of an O-ring type gasket then just a flat gasket.
If you can, it would probably be wise to get the proper gasket for things meantioned though. Unless its unavailable, then you can always try to make them. Theres only one way to find out..![Smile](https://cbrforum.com/forum/images/smilies/smile.gif)
Something to consider, if your O-rings are flattened out and not sealing anymore, you can remove the O-ring, place a thin layer of gasket maker in the groove and let it set up a little. Then, put the O-ring back and put it on the carb. This will push the O-ring back up a little and allow it to seal again.
ive done this, and its not a good idea, if any of the sealant sqeezes out into the bowl area, gas will degade it and it will wind up as trash in the bowl and eventually clog the jets, i was trying to save the bux on the proper kit, i did a perfect carb job and the bike ran perfect for two weeks and then slowly started to go to chit,, a member here told me if i used sealant , that was my problem, he was right.upon ttear down i found little pieces of sealant blocking little ports.
