Lowering Links
Whats a good place to buy lowering links from you guys?
The moron I bought the bike form has a metal beam in there with NO flex it rides ruff and I dont want it bouncin in corners I would put a stock shock in there but damn it'd be sittin high as hell anyone?? |
RE: Lowering Links
Word to the wise. Put your bike back to stock height. If you are having problems reaching the ground, shave the underside of the seat. Motorcycle engineers have the bike height set at a specific height for a reason. They are tested and proven to perform at a certain height. Lowering a motorcycle can cause all kinds of problems. It's not like a car, when you lower it you get better handeling. With motorcycles you get less clearance, less lean angel, and worse handeling. In fact most of the motogp and ama superbike riders you see racing have their bikes set up at factory height or alittle higher. |
RE: Lowering Links
well the guy I got it from took the shock out and threw it away
But I dont wanna go real high cause its LOW right now but maybe medium where can I get that special link at? |
| All times are GMT -5. The time now is 08:01 AM. |
