low beams
Old Apr 6, 2006 | 08:31 PM
amadres's Avatar
Default low beams
Is there a way to have both head lights on in the low beam position??
Old Apr 7, 2006 | 12:42 AM
transamlt1man's Avatar
Default RE: low beams
i know it can be done but I would have to see how it is wired right now.
Old Apr 9, 2006 | 09:59 AM
philly's Avatar
My RR has a screw behind the headlights on each side. Turning the screw adjusts the vertical height of the beam. I use both lights now with the main beam lowered so as not too blind everyone. Park the bike about 8 feet from a wall an start to adjust the beam, you'll see it going either up or down as you're doing it. Just bring it in line wth the other light.
Old Apr 10, 2006 | 05:12 AM
DThompson's Avatar
You can but the headlights are possitioned differently, you would either have your brights on and it would look like dims or you would have your brights on and they would both be brights.
They would be positioned at the same angle so you either get all brights or all dims
Old Apr 10, 2006 | 11:52 PM
Dragon's Avatar
Just adjust the high beams down...it works...
Old Apr 19, 2006 | 03:37 AM
amadres's Avatar
where is the adjustment screw located? I have a 05 1000rr
Old Apr 20, 2006 | 02:31 AM
jorge13's Avatar
Any knows where to adjust beams in the F4i 2006 ?
Cheers
Old Apr 20, 2006 | 09:36 AM
Anubis's Avatar
ORIGINAL: amadres
The screw is located at the top outer corner of the lights, looking at it from where you`d ride.
Old Apr 20, 2006 | 05:08 PM
amadres's Avatar
thanks
Old Apr 20, 2006 | 05:37 PM
Tahoe SC's Avatar
if you want to run both lights at low beam and then both at high, you need to convert to H4 bulbs.
