Keyless ignition?
Old Mar 2, 2010 | 10:13 PM
nickstanislaus's Avatar
Default Keyless ignition?
Could someone please tell me how to make my 02 f4i keyless? It is for my stunt bike. I could just relocate the ignition switch but would really like to get rid of. I have a problem with dropping the volts for the fuel pump.
Old Mar 3, 2010 | 05:18 PM
skoobydoobie's Avatar
The ignition has a diode in it to prevent hot wiring. I'm sure if you knew the specs on the diode you could get one at Radio shack or wherever, then be able to hot wire it. Or, I have an ignition with the key busted off in it that can be turned with a screwdriver or anything you can stick in the hole for that matter. Oh and I think the diode is hooked up to the pink wire.
CJardine
Nov 8, 2019 03:40 AM
cooltim
Jun 5, 2011 11:46 PM
02f4irider
Sep 25, 2009 05:45 PM
02f4irider
Sep 24, 2009 06:16 PM
dirtysanchez
Aug 28, 2006 09:46 PM
