-   General Tech (https://cbrforum.com/forum/general-tech-9/)
-   -   Keyless ignition? (https://cbrforum.com/forum/general-tech-9/keyless-ignition-106659/)
nickstanislaus Mar 2, 2010 10:13 PM
Keyless ignition?
Could someone please tell me how to make my 02 f4i keyless? It is for my stunt bike. I could just relocate the ignition switch but would really like to get rid of. I have a problem with dropping the volts for the fuel pump.
skoobydoobie Mar 3, 2010 05:18 PM
The ignition has a diode in it to prevent hot wiring. I'm sure if you knew the specs on the diode you could get one at Radio shack or wherever, then be able to hot wire it. Or, I have an ignition with the key busted off in it that can be turned with a screwdriver or anything you can stick in the hole for that matter. Oh and I think the diode is hooked up to the pink wire.
