InterNatrix Install
can someone help me with the install of my internatrix alarm? just got it and found some info bout it on the forums but need more specific help like where to wire the "ACC" (where is it, how does it look like?) and where i can find the kickstand wire i'm supposed to attach to.
I own a 05 600rr. It would be great if u guys could help me. Thanks. |
RE: InterNatrix Install
idk hwo diff my 06 f4i and ur 600rr are but its easy. the acc wire on mine was pink, good way to test cut the wire u think is the acc, if she doesnt start then shes the right wire hwo i did mine and works perfectly. as far as the kickstand wire u can bypass that but its easy check aroudn the kickstand if u dont have a book(very good investment btw) and look for sensor then follow the wire all the way up. do a search a guy on here not to long ago installed this alrm on his 600rr
thanks for the help and i found that post but he wasn't too specific on the wires. What color was the wire for the kickstand?
should i cut the acc wire and then attach all 3 ends together and duck tape? (sorry i'm noob) also, where'd u put everything cause i have a power commander and led kit under my seats. any ideas? |
| All times are GMT -5. The time now is 08:50 AM. |
