installing flushmount front turn signals
Old Feb 16, 2006 | 10:31 PM
hus600's Avatar
Default installing flushmount front turn signals
doing my own install on front flush mount turn signals. need help getting stock lights off. PLEASE HELP THANKS
Old Feb 16, 2006 | 10:39 PM
doncollins's Avatar
Retired Administrator
Default RE: installing flushmount front turn signals
What do you need? You need to remove the plastic so you can get to the back side and take the stock lights off. It's easier than it sounds.
Old Feb 16, 2006 | 10:49 PM
hus600's Avatar
I'm a dummy. I guess that's what I meant by needing help. How do I take the front off. I removed every bolt and every piece of hardware that seems to be holding the plastic, including mirrors but I still can't get it off. What am I not seeing? Thanks
Old Feb 16, 2006 | 10:59 PM
doncollins's Avatar
You're not a dummy... a dumb *** would have ripped it all off in pieces and came here asking where to buy cheap plastic.
Ok, so you have all three hex screws on each side, then you remove the plastic rivets that hold the inner covers on and they snap loose from the tank. You have, I believe, three, maybe four plastic rivets on the inside area near your front fender that hold the vent ducts in place. Remove those. Your mirrors are you main/strongest mounts. After the mirrors are off pull up slightly to clear the brackets. Then you go to the front and pull straight forward. There are two pins/post near the head light. Then you have the wiring/plugs to deal with. You have enough room to leave them connected if you like. I use a towel and a sponge on my fender to rest the plastic on so I can do the work.
Hope this makes sense... If not, I'm standing by for a few minutes for you.
Old Feb 17, 2006 | 12:34 AM
doncollins's Avatar
Hello.... a little feed back.... how's it going?
Old Feb 17, 2006 | 01:02 AM
hus600's Avatar
Sorry man, had to go for a bit. I'm about to try it now. It already makes more sense. I guess it sounds like I have to do both sides at the same time. I was trying to do one side at a time...DUH! How much flexing can this plastic take? I'm afraid of pushing and bending to much. My bike was ran over while parked a few months ago and had $3700 in damage for what seemed to be only scratches. So I know how expensive these plastics are. Thanks again for the help and I apologize for not respomding right away.
Old Feb 17, 2006 | 01:44 AM
hus600's Avatar
I did it!!! Thank you for the tip. I would've never figured out to lift up a bit before pulling it off. I also had a few of those plastic rivets to go that I had'nt seen under the headlights. Muchas Gracias!
Old Feb 17, 2006 | 06:54 AM
doncollins's Avatar
Great... I'm glad you got it. What flush mounts did you go with? Post some pics when you have time.
Z Freak
May 29, 2010 04:47 AM
BRRandon
Nov 19, 2007 04:22 PM
cande17
Apr 20, 2007 12:07 AM
CBRgator
Jan 20, 2007 06:10 PM
ciupe
Mar 17, 2006 10:53 AM
