Ignition wiring help
Old Jun 10, 2017 | 05:16 PM
cbrbike's Avatar
Question Ignition wiring help
Hello. i've got a question. let's say before changing anything wire "set 1" connects to the primary winding of the #1 ignition coil. the wire "set 2" connects to the primary winding of the #2 ignition coil. coil 1 fires #2 and #3 cylinders. coil 2 fires #1 and #4 cylinders. let's assume that in this order the bike runs very well without any issue in ignition side.
so what if i put the wire "set 1" to the #2 coil and wire "set 2" to the number #1 coil. will they still fire at the correct time or will it be a problem? will the TCI recognize the crank position and still give the correct command to generate the spark at correct time ? or if i change it do i need to change the HT leads as well according to it ? please give a brief explanation. thank you.
Old Jun 13, 2017 | 03:23 PM
CaBaRet's Avatar
Hi, I think if you look at "wasted spark", that will explain it
Old Jun 16, 2017 | 04:04 AM
cbrbike's Avatar
wasted spark means firing both spark plugs in the same coil at the same time. am i right ? this is bit different from my issue. thank you very much
Old Jun 16, 2017 | 05:34 AM
74demon's Avatar
If what you're asking is if it will work to switch the wires to the coils, then no. Your basically wanting to fire each cylinder 90 degrees off.
Old Jun 18, 2017 | 04:00 AM
cbrbike's Avatar
yea. simply i mean if i plug wire "set 1" to the coil #2 and wire "set 2" to the coil #1. will it still fire correctly at TDC in each cylinder and run the engine as usual ? thank you.
Old Jun 18, 2017 | 10:22 AM
CaBaRet's Avatar
Hi ,as 74Demon has already said ,it's not going to work, you have to understand how the Ignition Impulse Generator works in conjunction with the ICM, it sends an impulse to the ICM and sending that impulse down to the coil, although the coil has a Black/White wire on both coils the other two wires are not the same, one is Yellow/Blue and the other is Blue/Yellow ,both leading to the ICM ,if you cross them over your bike will never start
Old Jun 19, 2017 | 09:40 PM
cbrbike's Avatar
right. yea i checked it and you are correct now i got it. thank you very much for the help
jacksla3
Mar 13, 2014 05:02 AM
wookster
Mar 2, 2011 09:34 AM
dan_68c
Jul 8, 2010 08:27 AM
bindelsf2
Mar 22, 2007 03:58 PM
