Ignition CBR 1000 F
Hi
I just replaced the timing chain of my Honda CBR 1000 F (among other things) and now I can't get it to start.
I probably turned the crankshaft half a cycle (1 revolution) too much and the ignition is now not on the compression stroke.
Can I check this visually somewhere?
Or can I swap the ignition coils to check this?
Thanks in advance for your response.
Greetings
CL
Greetings
CL
The ignition is not on a 2:1 cog - it's directly at the end of the crank? It only knows the angle of rotation, not what stroke is happening - recheck your crank to cam alignment maybe?
