Ignition Barrell
Old Jun 18, 2014 | 10:23 AM
Dan Chapman's Avatar
Default Ignition Barrell
The ignition barrel works on my CBR 600 F2 1993 model but when i turn it on as normal it sometimes loosing power cuts out completely, if i turn it back towards off position very slightly (about 3mm) where you feel little resistance! its fine not an issue at all! anyone give me an idea why?? and also is there a way of sorting it or just a squirt of WD40???
Old Jun 18, 2014 | 09:04 PM
CorruptFile's Avatar
June 2013 ROTM
Sounds like a worn keywork or loose connection. You can try spraying some electronic cleaner down there. I'd sooner remove the barrel and see if you can see a loose or short in the bottom.
dylanhunter
Dec 5, 2013 04:13 PM
Alex Poucher
Feb 14, 2013 09:29 AM
DagonRais
Apr 14, 2011 09:32 PM
Di3eZiie
Feb 4, 2008 02:32 AM
