-   General Tech (https://cbrforum.com/forum/general-tech-9/)
-   -   idle problems (https://cbrforum.com/forum/general-tech-9/idle-problems-63321/)
jabs83 Mar 24, 2008 04:41 PM
idle problems
My seems to be idling roughly. Heres the backstory:
I own an 88 cbr600f hurricane. I crashed it a few weeks ago, and afterwards it idled at very low rpms. I got it home, and adjusted the idle screw to get the idle around 1500rpms.
Even though I got the idle adjusted, the engine cant seem to hold a steady rpm. The needle on the tach fluctuates. And sometimes even dips below 1500 and rises back up after i give it some throttle.
This is my first bike, and very new to maintenence. What should I do to get my bike to idle at a steady rpm? What should I check, and what maintenence would be required. Any help would be appreciated.
fireblade929 Mar 24, 2008 06:41 PM
RE: idle problems
well if you crashed you must expect that some damage was done to the bike. start by getting a service manual and check your fuel system (carbs, airbox, fuel lines etc) if you adjusted the idle screw and it died again then something must be wrong.
winks900rr Apr 7, 2008 06:49 PM
RE: idle problems
try to sink the carbs back
