i need help with my first bike
ok so i bought this 2004 cbr 600 f4i as my first bike he said it ran a month ago but now it dont it has been wrecked i turn the key the fuel pump does not come on however the fuel pump does work i took it out and put a wire from positive and neg it turns on but the fuel pump relay has not juice to it and the fuel pump doesnt get juice idk what the hell it is the ECM black and white wire that runs to the relay has no juice either but bike does turn over turns on turn signals everything works but that relay and pump what can it be?
Don't bypass anything unless it's mandatory needed to run bike temporary. Electrical can be a bitch once gone bad...try to savage, cheap fix....Replace.
Big Grey headlight harness. Jump the green and red wires together, then your good. Should start right up. I had to do this to my bike after I wrecked and was running it with no plastic's for awhile.
There are many posts about this in the F4i section. Just type bypass bank angle sensor in the search and you will find alot
