hurricane 600 14t front?
would dropping from stock 15t /44t to 14t /44t be to big of a jump ,
bikes running great , could use some more low end off the line . and really want add a tooth or 2x , 45t or 46t on the rear , but will be more complicated than just changing the front , for basic street riding around town ,knee dragging , some 2 up https://cimg7.ibsrv.net/gimg/cbrforu...fcf796748b.jpg touring bike has stage 2 , k& n ,.and f1 exhaust . was looking at buying a 2009 bandit 1250 , more low end torque, decided to keep hurricane tweak it out a bit . see how it goes . so far replaced the shock , found a used corbin seat .cleaned the carbs . new battery , new tires . thx! |
One less in the front is like adding 3 to the rear gear ratio wise. IMO, a smaller front sprocket forces the chain to make a tighter turn and makes it ride on the swingarm more (at least it does on mine). Better to make the rear sprocket larger for an easier arc and more clearance.
Originally Posted by 74demon
(Post 1318515)
