how to replace the levers
Should be an easy install, even though I have not changed my levers. Should be the hinge bolt and the cable attaching...that is about it.
If you would, let me know what you think when you get them installed. I am seriously considering ordering some for my 1000rr and maybe my F3...Would love to see the feedback!! Good luck...
i have those same levers on my 08 1krr, clutch lever- turn the adjuster to loosten the cable undo the nut on the bottom of the lever and turn out the flat head screw on top then unlatch the cable from the bottom of the lever, do this in reverse to install the new one and tighten the tention back up on the clutch cable to spec, the brake side you basically follow the same steps but there should be a "ball" like fixture in the new lever with a indent in it, some of them spin so just have to make sure the indent is lined up with the little shaft that sits in it, its really easy once you get into it not near as complicated as it may seem as your takeing the old ones off just remember the steps cause the new ones will go on the same way
![](https://cbrforum.com/forum/members/stretch_the_apex-40735-albums-new-beasty-08-1krr-1884-picture-a-9848.jpg)
Just nice levers
I have just posted up the Group purchase from www.rideitmoto.com in the F4i reigion .
Just cann't Waiting for getting these odds .
![Icon Hyper](https://cbrforum.com/forum/images/smilies/icon_hyper.gif)
