How do I change the clutch lever on a '96 F3
Are you talking about just the lever all the whole thing? The lever itself is just a matter of loosening off the cable (you can do that by turning the adjuster in) then undoing the screw & nut, remove the bolt/screw, old one slides out, the cable stock can now be slid out of the hole & cable groove, push the cable stock in to the new one & make sure the cable fits into the groove, don't twist it. slide it in, replace bolt & nut & bobs your aunty.
If your replacing the whole thing, you will have to remove the cable as described & then undo the bolts that hold the clutch body in place (body splits into two parts) put new housing on & then replace the new lever.
How do I change the clutch lever on a 96 F3
Hello
Please check the image that I attached, I want to change the location of link of forgot password and username to each other.
I mean I want the link of forgot username first and then forgot password.
Can anyone know in which file should I change?
I changed the file "default.php" in login folder in com_user, but didnt effect.
please help me in this minor change.
thanks
Chandu Gandhi
_____________________________________
Website I designed for payday cash advance company.
thanks
Chandu Gandhi
