-   General Tech (https://cbrforum.com/forum/general-tech-9/)
-   -   high beam for running daylight (https://cbrforum.com/forum/general-tech-9/high-beam-running-daylight-4682/)
rookie600rr Sep 20, 2005 06:45 PM
Any thoughts on using high beam during the day? good idea or bad idea?
too bad they don't make both lights come on for normal use.
chainstretcher Sep 20, 2005 06:47 PM
RE: high beam for running daylight
I use high beam during the day (and I'm running true HID's). Makes it a little easier for the cagers to see me -- I hope.
MapJr Sep 20, 2005 06:50 PM
Me and all of my boys run high beams all day long period. I don't want to hear "I didn't see him officer". I'd rather get the middle finger for bright lights in the rearview mirror than someone not seeing me.
Tahoe SC Sep 20, 2005 06:52 PM
running both beams during the day is a great idea!
also, if you want to customize and run dual headlights, check this post. should be similar for the RR.
http://forums.cbrworld.net/forums/42405/ShowPost.aspx
Turboedsupe Sep 20, 2005 09:04 PM
I run the high beams all the time and if i pull up behind someone i just flip them off. I use them at night and day time i would like to be seen
MgA_ODEN Sep 20, 2005 09:20 PM
Both day and nite , just aimed the high beam lower.
http://img397.imageshack.us/img397/6...84765457pl.jpg
rookie600rr Sep 21, 2005 03:29 AM
Thanks, I'll use both beams in the future.
RiPTOR Sep 21, 2005 02:47 PM
Both beams day and night all the time... unless i get stuck right behind someone at night i flick the high beam off. Otherwise it's both beams 24/7.
SynTeg Sep 21, 2005 03:33 PM
ORIGINAL: RiPTOR
Just wondering is the Highbeam and Regular Beam bulbs the same but aimed differently?
josho66 Sep 21, 2005 04:13 PM
I use it during the day, whatever I can do to be more visible.
