HIDS problem
hi riders
First of all i love hids.Upgraded my rr4 with 6k hid kit since then problems problems...
The problem is if i go to more than 30mph the hids stops working
. When going from 0 to 30 and i change gear, as soon as i pressed/depress clutch the the hid goes off/on, till 30mph after that im no light.
im using them as low beam. First i thought maybe the vibration or the hot coming from the engine its causing the problem but replaced it different place.so decided to ask for help to u guys/girls.
thanks in advance
. When going from 0 to 30 and i change gear, as soon as i pressed/depress clutch the the hid goes off/on, till 30mph after that im no light.im using them as low beam. First i thought maybe the vibration or the hot coming from the engine its causing the problem but replaced it different place.so decided to ask for help to u guys/girls.
thanks in advance
