Help with Steel lines please..
anyone home tonight that would be able to walk me thur the install over the phone?
i have read the instructions but cant seem to get it. also i dont have the bleeder Vac thingy... thanks guys, james EDIT: THANKS GUYS I GOT IT WORKING NOW... |
RE: Help with Steel lines please..
Use a turkey baster to remove the fluid from the resivior, remove old lines, you will get brake fluid on stuff so be careful. Install new lines. Fill master cylinder and resivior, start bleeding one at a time. It's hard to do the left hand side by yourself so maybe get someone to help. Open the bleeder, squeeze and hold brake lever. Close bleeder, release lever. Repeat until no air comes out of either side. Watch the resivior to make sure you dont run it dry and have to start over again with the bleeding. Hose bike off with water to get all the brake fluid off of things. Enjoy the new lines.
| All times are GMT -5. The time now is 09:23 AM. |
