Help with removing carburetors that have been on fo 10+ years!
I'm rebuilding a 1996 CBR 600/F3 and the carburetors have to come off to be rebuilt or replaced. That said, I've got them everything loose that's supposed to be, but they're still on there pretty good. I've been rocking them back and forth, and while they're a little looser they're a long way from coming off. Does anyone have some advice on getting them off?
Thanks in advance.
Thanks in advance.
So in the end, I hit boots with WD40, and then dropped a hair dryer in the gap so the hot air went under the carbs. I let it run for about 15 minutes, rocked it a bit while the hair dryer cooled a bit, then I let it run for another 15. After the second round with the hair dryer I rocked it a little more, then took a pry bar and gently moved it. They came right off!
Thanks for the help!
