HELP!!! ELECTRICAL PROB!
Old 03-17-2008, 12:55 PM
rd05f4's Avatar
Default RE: HELP!!! ELECTRICAL PROB!
also on my bike thers a 30a fuse but it doesnt seem like its connected to anything would it be worth it to just drop the like 20 bux and replace every fuse?
Old 03-17-2008, 01:11 PM
bluej511's Avatar
Unless there all blown no need.
Old 03-17-2008, 01:37 PM
rd05f4's Avatar
ya do you kno what the IND means on the fuse box its the 3rd or 4th down and it says taillights as well you think that could have caused my dash to stop working to?
Old 03-17-2008, 02:09 PM
elmer's Avatar
I haven't seen a fuse box for that particular bike, but my guess is the IND stands for Indicator lights.
Old 03-18-2008, 04:20 PM
rd05f4's Avatar
Ok so i unhooked the flushies and replaced the fuse that was blown the 10a IND meter, taillights and guess what everything works now thank god! but does anyone have a wiring diagram??? i need to kno what wire to cap off now so that the signals work and dont short the fuse my wiring set up is (LEFT) Orange Orange with white stripe and green. (RIGHT) Blue Blue with white stripe and green. What one do I cap off??? anyone with an 04 05 06 F4I done flushies and know?? I dont think the wiring has changed at all for those three years I actually think its the same from 00-06 so any input would be nice i wanna get bak to riding need my signals!
Old 03-20-2008, 04:01 PM
mcwheelie08's Avatar
do your flushies have two or three wires comin out of them
Old 03-23-2008, 01:26 AM
rd05f4's Avatar
flushies are 2 wires
Old 03-23-2008, 12:26 PM
so when you wired them did you use two or three wires, and do you own a test light
Old 03-23-2008, 12:45 PM
you still there or are you out riding enjoyimg this beautifull day any how listen this is how it goes you have 3 wires there on the front of your bike one wire is a ground one wire is turn signal wire and one wire is marker light wire if you have a test light hook it to your positve battery terminal and begin lookin for your ground no nit will not blow your fuses when you find your ground the tester will light up after you find your ground go ahead and connect it then switch your test light to the negative terminal you will want to have your key on and maybe even bike runnin so you dont kill your battery again , turn on your turn signal and prob remaining two wires till you see the test light blink like your turn signal would thats the wire you want to connect to your flushy now that third wire can be capped off unless you want to convert yoour flushy to marker lights also if so let me know and i will instruct you to do so
Old 03-24-2008, 06:29 PM
i am assuming that you got you problem figured out since i check this thread every day hoping to help but youv gone away like a fart in the wind ha ha !!!! let me know if ya need any more help
Quick Reply: HELP!!! ELECTRICAL PROB!
