HELP!!! ELECTRICAL PROB!
OK so basically I put my new flush mounts on and failed to realize i left my bike on so my battery died I jumped it and let it run and looked at the console and realized that NOTHING was working. I.E. tach, speedo, mileage, temp.
the signals work the signal symbols work same with bright N, and FI.
How can I fix it with out going tothe shop??
You can jump from a car as long as the car isnt running. A car usually puts out around 14volts or so while running. A bike only needs 6v to start im sure. But still has a 12v battery, if your trying to jump your bike from a car make sure the car is OFF.
And yes check your fuses. Always start at the source ie battery then work your way up.
i checked the battery dead bought new one prob solved ther still no dash stuff or tail lights checked fuses all good minus the 4th 10a fuse that sez tailights INDand sumthin else any one know what that one is?
haha thats what i was thinking and thanks for the motivation haha
i think it may be the ground wire from the flushies. would thos flushies be the reason for my dash not working??? or is that another issue?
