HELP 96 cbr 600 breaking up
hi there my name is Ben. i have a 96 cbr that has been set up for stunting. it has a 60 tooth rear sprocket and has no fairings. i bought it as is and it ran great for about 3 days then one day i was on the interstate doing about 65 or so and it started breaking up it felt as though i was turning off then back on again. so i brought it home for the next few days it would do a little here and a little there as the days went on it got worse.
as of now i have:
replaced the plugs
cleaned the plugs again
new carb holders the old ones were really cracked
cleaned the carbs
so please help me out here it sux having this bike that i cant ride!!!!!!!!!
thanks ben
as of now i have:
replaced the plugs
cleaned the carbs
thanks ben
If it was used for stunting the first thing I would do is check the tire pressures and the oil level. Probably won't help your cause, but those guys change things to make stuntin easier. Second,for your problem, I would look at the wiring, specifically the switchgear that has the engine kill switch. It wouldn't surprise me to find it damaged there. Otherwise check all your wiring, make sure you have clean and tight connections and good grounds.
ORIGINAL: CB750
I would check the kill switch/kickstand switch..check wiring.
i agree it should have a fuel pump but it ran without so i think that it is something else none the less i am going to get one to eliminate that as a possible cause
oh and the problem happens when trying to cruise say at like 40 i have tried to ride in 4th 5th and 6th all the same problem so it dosent matter what the rpms are.... now if i get on is say through 1st 2nd and 3rd it seams to be ok....
thanks again guys i am going to work on it tomorrow ill let u guys know
