Help!!!
on
1 Post
^^^^^ + How old is the coolant?. I'd be draining the coolant & giving the radiator & motor a good flush anyway if you suspect an air pocket. The point that coolant boils at goes down if the coolant is old or been diluted by adding straight water to reserve bottle. Nearly forgot to add, if your having to top up water pretty consistently then a possible head gasket leak
