-   General Tech (https://cbrforum.com/forum/general-tech-9/)
-   -   fuel pump wont shut off (https://cbrforum.com/forum/general-tech-9/fuel-pump-wont-shut-off-145911/)
krazykarl Apr 8, 2013 09:06 PM
so i am new member to this form but have frequently visted it for mnay years and have finally come across my first pronlem i can not solve! i have a 2003 cbr954rr, when you turn the key to the on postion and the bike runs all of its functions checks etc the fuel pump primes the line, you can audibly hear it every time you turn the bike on for about 3-5 sec then it stops. welll mine DOSENT.... it always continously running even after the bike starts, i checked the realay, and tip over sensor, grounds etc... i unfortunitly believe its my ecu? dosent any one have any insight on this matter can hopefully prove me wrong :icon_errrr:
also if it is the ecu can i over ride this problem with the purchase of a power commander or some other fuel/ignition programmer?
74demon Apr 8, 2013 09:44 PM
Did this problem just start or did you get the bike doing this?
krazykarl Apr 10, 2013 06:03 AM
Just started doing it it was flashing a code one day then just stopped and was fine so I played no attention to it then it started to run all the time and Is either flashing 2 different codes or flashing one Idk I got to check the manual
