Fuel leak at 3 way joint from carb fuel tubes
Old Mar 28, 2013 | 03:54 PM
cc rider's Avatar
Default Fuel leak at 3 way joint from carb fuel tubes
Hey guys. I got a 99 cbr900. Just put her back together. I had taken apart and cleaned the carbs over the winter plus some other maintenance. Trying to get ready for riding here. The leaking is only at the 2 joints where the carb tubes go in to the 3 way connector. There is no leaking at the other tube (the one going to the fuel valve). Also, it only starts to leak when i start the bike. Is this a carb gasket or something? All the fuel tubes seemed to be connected tight. I tried reconnecting everything twice. Or are those fuel tubes just worn?
Old Mar 28, 2013 | 04:23 PM
CorruptFile's Avatar
June 2013 ROTM
Old rubber loses is elasticity and eventually isn't able to form a good seal. You don't need special fuel line, just generic fuel stock with suffice. Just bring in a section to the autoparts store so you can compare the I.D.
Old Mar 28, 2013 | 05:24 PM
cc rider's Avatar
ok. Thanks a lot. Ill try changing both tubes. I hope its that easy. I was getting ready to sync the carbs. I have to adjust the pilots . I took them out when cleaning the carbs and forgot to count the turns!!!. I put them at their initial setting at 1 5/8. I have the factory manual that explains the procedure. It seems a little confusing but that's a whole other post when Im ready.
Old Mar 29, 2013 | 03:54 PM
Items 7 and 8 are most likely the culprits. The O rings on the T's go bad and leak. Especially if carburetor cleaner got on them. Make sure you clean any corrosion off the carburetor body where they fit into as well.
Honda Motorcycle Parts 1999 CBR900RR A CARBURETOR ASSY. Diagram
Old Mar 30, 2013 | 12:39 AM
cc rider's Avatar
But , they are only leaking on the joints where tubes 27 meet tee 25. Not anywhere else. I was going to try some small hose clamps on there. But, i just ordered the hoses since I'm not riding it anyway till the weather breaks. Partzilla is awesome by the way. I find they have the cheapest prices. The shipping is a little slow though.
Old Mar 30, 2013 | 07:47 AM
Well if that's where it's leaking, then that certainly is a much easier fix. New hoses and you're good to go. Those hoses must be in really bad shape to be leaking.
Most leaks relating to the fuel supply are related to the O rings on the T fittings that connect in between the carburetors. During the cleaning process and taking the carburetors apart, the tubes and O rings get moved around. The O rings are not nearly as flexible as they were and just don't seal properly. Here's to an easy fix.
Old Mar 30, 2013 | 07:59 PM
cc rider's Avatar
hose clamps did the trick
iceman423
Nov 6, 2022 06:20 PM
F4Mike
Nov 22, 2010 09:06 PM
lanceam24
F2 Tech
Apr 16, 2010 06:23 PM
Ty_Deschaine
Jul 6, 2008 03:19 PM
getofobulus
Jun 15, 2005 09:46 PM
